The Redheads RV-7A Build SIte
Date:  2-3-2008
Number of Hours:  4.00
Manual Reference:  Section 6
Brief Description:  Building the Rudder
Fitting the Stiffeners to the Rudder Skin
Fabricated two R-918 Bottom Attach Strips from 0.032 thick 2024-T3 alclad aluminium. Cut R-915 stiffeners from supplied aluminum angle and marked areas to be trimmed. Used a combination table sander to clean up the edges resulting from cutting individual stringers from supplied aluminum angle.
Fabricated Two R-918 Bottom Attach Strips
R-915 Stringers Cut from supplied Al Angle
Using Rotary Sander to Fiinish Trim Edges of R-915 Stringers
