The Redheads RV-7A Build SIte
Date:  12-15-2007
Number of Hours:  3.00
Manual Reference:  Section 6
Brief Description:  Drilling the Horizontal Stabilizer
Located holes in HS-404 Nose Rib and HS-405 Main Rib per Section D-D. Cleco'd all underlying structure together and drilled all rib-to-spar-to-rib holes then cleco'd HS-601PP skin to the underlying structure. Match drilled skin to underlying structure.
Match Drilling RH HS-707 Nose Rib to HS-702 Front Spar for LP4-3 Blind Rivets
Clecoing RH HS-601PP Skin to underlying structure
Drilling HS-601PP Skin to underlying structure
