The Redheads RV-7A Build SIte
Date:  7-28-2008
Manual Reference:  Section 6
Brief Description:  Priming the Empenage
For the most part I chose to hang parts from above using safety wire with the idea that I could get access to all sides of the parts that way but in the end I wound up setting up a low shelf and setting many parts on it. I means I will have to spray those parts a second time.
I purchased the forced air system (Hobbyair with the full face mask) from Aircraft Spruce in Corona, CA, the one-piece Tyveck suit (purchased 5 suits) and rubber gloves (5 pair) from Gemplers, and the spay gun (DeVilbliss Starting Line) and DeCups kit from Eastwood.
The primer is from Sherwin Williams CM0484900 Corrosion Resistant Epoxy Primer.
Cleaned Skins Set on Work Table
Cleaned Parts Hanging in Paint Booth
What the Well Dressed Painter is Wearing this Season
