The Redheads RV-7A Build SIte
Date:  12-2-2007
Number of Hours:  4.00
Manual Reference:  Section 6
Brief Description:  Drilling the Horizontal Stabilizer
Drilled LH HS-601PP skin to underlying structure, including HS-706 Tip Rib, HS-707 Nose Rib, HS-708 Main Rib, HS-702 Fwd Spar, HS-603PP Rear Spar, HS-404 Nose Rib and HS-405 Main Rib.
Match Drilling LH HS-601PP Skin to structure
