The Redheads RV-7A Build SIte
Date:  11-10-2007
Number of Hours:  3.00
Manual Reference:  Section 6
Brief Description:  Replacement Parts Arrive
New HS-710 and HS-714 parts arrived from Van's Aircraft. Marked the parts as before then cleco'd to the HS-702 front spars for match drilling. After deburring, marked for trim operation and cut with bandsaw again except this time did not trim as closely to the trim lines. New parts have edge distances per drawing and will replace original parts.
As found on front porch
