The Redheads RV-7A Build SIte
Date:  11-3-2007
Number of Hours:  3.00
Manual Reference:  Section 6
Brief Description:  Front Spar Assembly
Used a Vixen File and the Scotchbrite wheel to smooth the bandsaw trimmed edges to a smooth finish. In the end decided that I had cut too close to the final dimension with the bandsaw - after finishing the edges the final parts were well inside the lines originally marked. Ordered new parts from Van's Aircraft.
HS-710 and HS-714 after trimming with bandsaw
Using Scotchbrite wheel to smooth bandsaw cuts
Using Vixen file to form end radii
