The Redheads RV-7A Build SIte
Date:  11-2-2007
Manual Reference:  Section 6
Brief Description:  Deburring parts and Front Spar Assembly
Completed deburring HS-603PP and HS-609PP (Images 1 and 2).
Cleco'd and matched drilled HS-710 reinforcement angle and HS-714 splice angle to two HS-702 front spar channels. Deburred all parts following match drill operation.
Marked HS-710 reinforcement and HS-714 splice angle to indicate how the ends should be tapered and radiused.
Deburring HS-609PP
Deburring HS-609PP
Deburring HS-603PP
Deburring HS-603PP
