Brief Description: Setting up Dynon system, Prop on order
Tring to get the Dynon system to accept the signal from the engine to let me know how much fuel I am burning in flight. This usually is very accurate and lets you know how much fuel you are burning and what is left in the tank. If set up properly it will be within a few onces and you can adjust your engine speed for the best economy. The prop has been made and is in transit to be delivered on July 16th. Once I install it I should be ready to see if the engine will start !
