TERRY'S WEB SITE
Date:  3-12-2014
Number of Hours:  4.00
Manual Reference:  42C-02
Brief Description:  Started on the avionics
Installed the SV-50000A RV-12 Control Module.
Just about everything else will plug into this.
The kit comes with the wiring harness connections and everything is labeled on the module to show you were to plug it in. It has the name and is also color coded on the box and harness so you don't have to know much about wiring.
The next step is to plug in the fuselage and options harness.
Installed the SV-EMS-220 onto the inside firewall and plug in the two connectors.
The center panel has to be put in place and check to see if the radio fits in properly.
They have changed to a new radio and it is higher so you have to open the top of the opening about 0.050 bigger. Marked the opening and removed it to file the material off.
With the new radio they also made some changes to the instrument stack angles so you have to remove the old ones and install the newer ones.
Put 3M Carbon Fiber on the face of the panels.
This is for looks and I think it will last a long time. It will not scratch as easily as paint.
On page 42C-05 installed the center panel to the supports with it over the AV-50001 Power & Switch Module. This makes it recessed and no outside face edges showing
Just the beginning
Just the beginning
