Skipping oil tank support because I'm not using the Rotax engine. Made the F-1240C clip and riveted it to the F-1240B Coveer plate. Curved by hand the forward edge on the F-1240 upper forward fuselage skin. Final drill #19 all the screw holes and dimple. Put upper forward skin into position and install screws. Cleco and rivet nutplates to the F-1202D L&R panel attach strips and then rivet into place on the upper forward skin.
