Brief Description: put in screws in bottom, pret parts
Put in 6 screws into bottom skin inside the tunnel with help. It would of been easier if you put these in before you put the skin in place because you could of done it easily without needing two people. Once the skin is in place you can not hold a screw driver and reach around and put the nuts on. Worked on locating the parts for the next section and deburring and getting ready to prime. Will have to countersink parts and attach nut plates next
