TERRY'S WEB SITE
Date:  6-29-2013
Number of Hours:  4.00
Manual Reference:  1704
Brief Description:  Started putting on the skins
Took plastic off inside of bottom skins and sprayed with Zinc Chromate.
Outside used soldering iron to melt plastic and remove where rivets will be used. You can see this in the shiney stripes in middle picture
This will help prevent the skins from being scratched and will be removed prior to paint preperation.
Riveted the bottom inboard skin in place and positioned and cleoed the outboard bottom skin in place.
Not enough time to rivet it today.
Spent 10 hours at the hanger today.
Time flies by when you get busy sometimes!
prepping skins
prepping skins
Riveting inboard bottom skin
Cleco outboard skin in position
