TERRY'S WEB SITE
Date:  4-16-2015
Number of Hours:  10.00
Air inlet on the baffle covers did not line up with the cowl inlets as you can see in image1.
Had to cut off the original one and make a new inlet with a flange so I could move it and get it to line up then fiberglass it back on. The new one was larger on one side so I had to cut the side out of the cover and add to it so the air wasn't restricted. Not a fun job.
Had to do this for both sides.
air inlet on baffle cover
Adding the cloth and resin to hold it all together
Both sides cut off and moved
