Brief Description: Canopy guides and attach canopy to frame
Center the C-1206 metal guide pieces that will fit into the guide block slots and drill and rivet onto canopy frame. Fabricate C-1210 canopy lift handles from angle alum. Put canopy in place and cleco. Check for the proper clearance. Then I had to remove and do some more trimming. Put back on and cleco to check it again. Looked good so I riveted the front rivets and riveted the side skirts in place with the canopy lift handles. Installed the screws in the side skirts.
