Received an email from another builder that is also using a different engine than what the kit usually comes with. He had tested the electric fuel pump and with only 1-2 gallons in the tank it would pump dry quickly so he modified the baffles and the fuel return line. I figured I had better do something also so I had to pull the tank out and open it up again. I will put more holes in the baffle that goes from the front left chamber into the right intake baffle area and have the return line flow into the left chamber also. Didn't really want to do it but it is better to do it now than have a problem later on.
