Installed wire harness going to the switch module. Install Autopilot harness into control box and then put Autopilot disconnect in the hole in the lower bottom of the panel next to the Throttle hole. Then attach molex plug to the wires on the button and the mating plug onto the wires going through the pan bottom bushing and connet to the button wiring plug. Attach the SV-XPONDER-261 Mode S transponder and mounting tray to the firewall and then run harness to the control module. Attach antenna cable to the transponder and attach antenna to the underside of the plane. Attach the Com Antenna to the plane and the antenna wire that was installed before. Mount the left panel face and the Ignition & Staqrt Module and the Skyview display screen. Install all wire harnesses to the Skyview and Ignition module. Mounted the ADHARS and hooked up the wires and tubeing for the Pitot, Static, and AOA systems. Did not install the GPS antenna at this time but will do it after the engine is installed.
