Brief Description: Flange for forward tank bulkhead
Worked on the flange and riveted it to the forward tank wall also put nut plates where required. You can see in the picture the front of the tank and the flange and nutplates are on the inside where the big hole is. That is where the cover goes that holds the fuel sender assembly. Picture # 2 shows you an inside look of the parts in the plan drawingt
