TERRY'S WEB SITE
Date:  10-12-2013
Number of Hours:  8.00
Manual Reference:  29A-08--29A-11
Brief Description:  Finish Map Box & attach tailcone
Completed Map Box Assembly and worked on other two panel fronts.
Riveted on the Skyview reinforment angle to left panel face. Added nutplates where indicated.
Put nutplates on center instrument panel and then modified it where the throttle is attached so you can remove panel if needed and not have to remove the throttle from the engine.
Went back to section 25-01 "Tailcone Attachment" and with the help of a friend put the tailcone into position and clecoed it. Page 25-01 - 25-03. It went together without any problems--easier than I expected.
My Co-pilots seat
My Co-pilots seat
Looking good !!
Looking good !!
Getting done
Getting done
