I removed the seat so I could work on the fuel selector valve. My goal is to have it secure yet allow the carpet to be tucked underneath. To do that, I raised the selector plate by lengthening the screws and adding 1/4" nylon spacers. I used "C" clips to hold the spacer in place. When that was set, I cut and attached the center spindle to fit. Next, I vacuumed the inside of the fuselage. Afterwards, I finished securing the rudder trim and tail strobe wires that will eventually come through the VS.
