Today I finished the ground power unit manufacture. I added a hole for the 5amp fuse and green LED indicator. As I disassembled it for the last time, I chamfered and dimpled the holes where needed. When done, I alumiprepped, alodined and primed with two part epoxy primer. Tomorrow I will rivet pieces together and install the unit.
