Finish sanded (#180 grit) the windscreen fairing and applied some quickset epoxy to the low areas. After it cured, I sanded it level with the surrounding area. Good enough for now. Next I reset the protective tape on the windscreen moving it so I could sand 3/8" around the perimeter of the windscreen. This will give me space to apply two layers of fiberglass covering the lord adhesive flexible joint. The purpose is to prevent cracks in around the window because the plexiglass and fiberglass expand differently. More sanding tomorrow.
