Sanded the forward section of the pilot door jamb and added epoxy/micro to the upper pilot door after prepping and installing vinyl tape and mold release on the door edge. Next the right door threshold was sanded. I removed the guide blocks and filled the three holes from the back side with modeling clay until it was flush. This may help reestablish the holes after the epoxy/micro cures. After wetting the surface, I covered the face in those two locations with epoxy/micro a little higher then the surface and plan to sand flush tomorrow.
