Sanded the left door jamb (forward/aft) where the pin guides will sit. I temporally installed them. I sit the rear one on AN washers because it is not thick enough. I have two on order. They will need further adjustment before it is all done. The door mechanism is working great. Next I installed the third (center) Plane Around latch. They too worked well. They will be removed one more time when I paint the doors. After making sure I had .015" around the right door, I added vinyl tape to the aft right door and smeared it with mold release. I then put a small layer of epoxy on the outside. This will be sanded when cured, and the door area to the right will be done. They will then be leveled together.
