Sanded the exterior of the right window/door. I removed the upper layer of vinyl tape on the windscreen and sanded the fiberglass level with the remaining piece of vinyl tape. I adjusted the gap around the left door to .015. for now and sanded the left aft window smooth at the joint. After prepping the surface, I wet it out with epoxy and added a 1/8" layer of epoxy/silica around the left aft window. This will be sanded tomorrow.
