Short day. I sanded the first pass fairing epoxy on the right wheel cover and upper/lower transition fairing. Once done, I cleaned the parts and applied "Superfill" (blue) for the second coat. Should cure in 8 hours...sand in 12. When done, I will finish with green filler that sets i 20 minutes. There should be very little of that needed.
