With the fuselage painted, the rudder/brake pedals could be installed. All the AN fittings were installed with sealant and indexed to receive its line. Some time ago, I decided to upgrade to Banaco brake lines. This was really a re-install because all the drilling and fitting was done a few months ago. Here I deviated from the prints by adding a parking brake. Even though it was a re-install, it took the full eight hours to get all the plumbing done. The AN3 brake line fittings were torqued to 70" lbs and the AN4 brake line fittings were torqued to 100" lbs. the lower gear gets installed next.
