Cleaned up the console adhesive and applied some cabosil around the door seal filling in any minor gaps left over from installing the seal ledge. I then made added some micro balloons to the epoxy and smoothed out the aft section of the console. Even though this will be covered by a headliner, I wanted it smooth underneath. While the glass was curing, I cut the holes for the 2" air ducts. The air ducts will be installed later so I will have access to the upper rivets to buck. The Hartzell propeller arrived today.
