Seemed like a long day today...more measuring, cutting, sanding and fitting the right side cabin door. I got the door rough fit complete except for removing the indexing tabs. These tabs hold the door in place while the door is being fitted. Once the rough fit is done, the tabs are removed, moving the door to its final position...and the final fit is done. Rather then start the final fit at the end of the day, I decided to leave that for tomorrow. I spent the rest of the day removing the left door (which was still attached to the fuselage from the glue up) and doing the finish cutting/sanding of the window.
