Received my lower wing fairing yesterday and shaped it for the left wing. Kris and I set the left wing in place and pinned it with two 3/8 bolts. The rear spar was pinned, clamped and drilled multiple times working up to 3/8. A drilled bolt was installed and castle-nut installed to hold it in place. I worked and installed the lower wing fairing. Set the upper fairing in place and drilled the fairing support angles for their nut plates. The wing was removed so I can add nut plates on the holes identified by placing the fairing on the fuel tank. Once done the wing will be reinstalled to test for final fit.
