Brief Description: Finished Right wing initial fit up
Finished the right wing attach, removed it from the fuselage and Kris and I put it back into the wing rack. All the parts need to be scuffed, alumipreped, alodined and prime painted...but I will wait until I finish the left wing so I can do all the parts together. Once the parts are painted, I will install the fairing stiffeners, nut plates and fairing attach angles. Kris helped me prep the left wing to receive the lower two nut plates. The fuselage was turned 180° and strapped to the carrier so I can start work on the left side. I don't know who first designed the fuselage carrier, but by adding a section to carry the tail and wheels, it is very sturdy as well as mobile. So thanks...good design.
