Worked on the wiring runs today. First was to come up with a way to install the RG400 coax later and to do that I installed 3" of Pex water line to use as a conduit run. I wrapped each end with safety wire to keep it from sliding through the bushing at each end. Worked well. I then made a couple brackets for the main battery wire and installed the wire cover on the left forward. Vans does not make one for the right side, so I plan to order some aluminum and make my own...just like the one on the other side.
