Brief Description: Seat structure and gear mount fit up
Manufactured the seat floor angles, floor attach strip, floor covers and floor. Also drilled and countersunk e mid seat rail supports. I plan to do a little more before I paint. I spent the rest of the day fitting in the L/R landing gear supports. They have to be temporally installed so the front gear mount support can be fit to the front floor pan and outside floor rib and drilled. I did this twice because the first time I forgot to temporally install the floor pan. After getting all the parts set in place and bolted down, the front support was marked and drilled.
