TERRY'S WEB SITE
Date:  5-9-2013
Number of Hours:  8.00
Manual Reference:  Section 20
Brief Description:  Wing Harness, Antenna Connection
Soldered on the terminals on the wires I ran in the 3/4" conduit in the completing the wiring harness on the outboard end. I still have to tie all the wires together at the Fuselage, but that will be a year or so from now. I also installed terminals on the RG400 Coax for the Archer NAV2 antenna in the left wing. I took the time to solder the terminals on rather then crimp to help with potential corrosion. Switching over to fiberglass, I secured the antenna top end by glassing it into the fairing. All wires were labeled with the Bradey BMP21 on nylon lables.
NAV/Position/Strobe harness Right Wing
Antenna lead with solder shield
NAV2 Antenna glassed in Left Wing
