Started to wire the right wing. I ran the wire for the HID lights in the leading edge, the shielded wire for the NAV/Position/Strobe, and put a tracer string in for the outside air temperature probe (OAT) that I will add at a later date. On the left side, I installed the wire bundle for the aileron servo, installed the wires for the pitot controller and also the NAV2 antenna. I went with RG400 double shielded wire... a recomendation from the RV10 builders group. I did not have enough wire to finish the power side of the pitot tube or the left wing HID lights. Ordered that today. I will work on the getting the pitot and its controller installed tomorrow.
I added to stick-on wire anchors to lift my pitot out of harms way from the bolt heads holding the left wing bellcrank. I need to noodle this a little more. While it will do a good job, I may remove them and put a metal clamp instead. Need to ponder.
