Brief Description: Sealed 80% of left wing fuel tank
Using proseal does not work well with cameras so photos are limited. Larry and I spent the day prosealing and riveting 5 interal ribs, one outboard rib, the aft side of the inboard rib, J channel and setting vent line. The clecos took about two hours to clean up... and I was glad I covered the work bench before starting. After a few days, I will install the fuel tank float and seal up the rear.
