Put in a few more hours on the left wing fuel tank. Mounted the fuel cap and drilled out all the skin/rib connections. Opened up the mounting screw holes to a size #19 and assembelled the rear plate with Z attachment angles. All parts will be alumipreped and alodined... but only part of the Z attachment brackets and mounting edge will be primed with two part epoxy paint.
