Removed the right side exhaust system and deburred the inside where I drilled for the EGT probes. Afterwards, I rechecked the probes for fit and reinstalled the right side exhaust...this time with the proper hardware for a final install. Once it was installed, I added the EGT probes and torqued the band straps. The CHT probes were installed next. When all this work was done, I safety wired all the EGT band clamps. The mag pickup was installed next in the left mag...it is a Slick #6393 retarded mag.
