TERRY'S WEB SITE
Date:  5-10-2016
Number of Hours:  8.00
Brief Description:  Service Bulletin SB 16-03-28
Vans Service Bulletin SB 16-03-28
I completed Vans Service Bulletin (SB) 16-03-28. Had to remove both ailerons and trim a piece of aluminum so I can verify there are no cracks in the spar or aileron support bracket that secures the inner aileron. By removing the small sliver of aluminum, the ailerons will not have to be removed in the future to inspect. The SB will remain active for the life of the plane.. Vans strongly recommends NOT adding doublers until absolutely required.
Marterial removed
Marterial removed
Inside Rivets
Inside Rivets
Inside Rivets
Inside Rivets
