More Misc. Installed all but 3 pieces of carpet. Cut and installed wing walk material. This will be replace when the plane is painted. Programmed the flaps to indicate position. Installed the rear seats and adjusted the seat belts. Verified the head set was still OK, but talking to an aircraft in the pattern at Mt. Hawley. Programmed the fuel level to audible "check fuel level" starting at 7 gallons on each tank. Audible will stop at 6 gallons. Best be finding a place to land by then.
