Kris worked a couple hours this morning removing the blue protective plastic covering. I worked on the prop, getting it ready to install Monday morning. After Kris left for the day, I pulled the airplane outside and wiped it down with MEK, removing all left over adhesive from the blue plastic covering. When done, I pushed the plane back into the hanger and worked on the lower gear fairings.
