Finished installing and adjusting the elevator trim. Plugged it into the aircraft system and it tested just fine. Next the Vertical Stabilizer (VS) was installed. I attached the rudder to the VS and secured all the fasteners. I then installed the tail fairing, lower horizontal stabilizer cover plates and the rear most side plates. Installed the rudder cables and tested for mobility and interference issues...all good. Electrically tested... LR Strobe, LR NAV Lights, taxi/landing lights, stall indicator and the taxi/strobe flashers. All good.
