Installed and tested the flaps. They set up in REFLEX when fully retracted. They are very smooth, with no interference or binding. Still need to document the actual angles for my POH. I installed COM1 and COM2 on the belly. I heat shrunk the fuel tank electrical connections and hooked them to the fuel quantity sending unit. I tested the aileron bias spring servo and operated the autopilot.
