I checked for torque all the brake line connections and marked with torque seal. I then bled the brakes replacing the air in the lines with 5606H mil spec brake fluid. I had success by pushing the fluid into the brake bleed fitting and letting the air push out the brake manifold on the firewall. I had a 90° fitting on the top and a 3' tube attached to capture the fluid being pushed out.
