Brief Description: Mini X USB connection manutacture
I purchased a 20" USB connection from Stein. This connection is needed so that updates can be installed without pulling the GRT MINI-X from the panel. I connected one end to the rear port and made a bracket that attaches to the pilot side air duct screws for the other end. It is accessible, out of the way, and also hides some of the side insulation seen when you stand on your head. :)
