Brief Description: Pitot pressure test and V speeds programmed
I checked the pitot system for leak down with 15" of water column on the manometer. At that setting, the MiniX indicated 26 kias and the G3X was starting to wakeup. The plumbing held just fine. While testing the pitot system, I installed the pedal extensions I ordered from JDAir. After that, I installed the jam nut on the aft tie down. I also double checked my air speed settings and reset the maneuver speed setting so it would show up as yellow on my gauge. I ended the day by adding a little more high temp RTV in voids on my baffling.
