TERRY'S WEB SITE
Date:  12-17-2015
Number of Hours:  3.00
Brief Description:  Retest fuel tanks
Final fuel tank pressure test day. Though I tested the fuel tanks when built, just did not have that 100% feeling, so I planned a retest. I installed a manometer at the tank out fitting, plugged the vent tube and put Vans valve in the tank drain boss. After hooking up a bicycle tire pump to the valve, I pumped it till the manometer registered 20" of water column (27" = 1 psi). Using a syringe, I carefully placed a drop of kids bubble soap on every rivet and along the seams and let it set. After a sufficient time, Kris helped me turn the wing over and test the other side. Both tanks are good to go. Yea!
Test each rivet with soap
Manometer set at 25
Manometer set at 25"WC
