TERRY'S WEB SITE
Date:  11-30-2015
Number of Hours:  7.00
Manual Reference:  12.5
Brief Description:  Tail fitting fit up
Match drilled and fit the rubber gap seal on the underside of the horizontal stabilizer (HS). Kris and I sat the HS in place and I bolted it in using temporary hardware. The Vertical Stabilizer (VS) was installed next. I cleaned up the empennage fairing removing misc epoxy bumps and sat it in place. It fit better then I hoped. I drilled the forward three screw holes and the removed it so I could dress up the front shaping it the same on both sides. After sanding it a bit, I reinstalled and (starting in the front working rearward) drilled/clecoed the remaining fairing attach screw holes in VS/HS and fuselage. I ended the day by marking all the final shape lines. Next, I plan to remove the fairing and trim to the lines. The fairing also has to be marked where the elevator horns are, but the elevators need to be installed first.
Tail fairing
Tail fairing
Tail fairing fit up
Tail fairing fit up
Tail fitting fit up
Tail fitting fit up
