Brief Description: Front panel and seatbelt holder
I removed the plastic from the windows. I assembled the left and right front panel with map and cup holder and installed them onto the panel. I planned to mount them with #8 flat head screws, but I had to change the center three screws to # 6-32x1/2 to clear the fuselage forward brace. Changing out the fasteners worked well. Next I installed the seatbelt holder. I used #8-32x1/2" SS hex head cap screws to secure it. Then I installed the headset holder on the forward brace, but it caused interference with map lights, so I relocated it about 6" aft on the overhead plate. That will work well there.
