TERRY'S WEB SITE
Date:  11-24-2015
Number of Hours:  6.50
Brief Description:  Overhead panels
I installed the Aerosport side panels and the side piece that trims out the interior of the cargo bay door. Next the rear seats were installed. They too were covered by Aerosport, and they did a fine job. I added "12V" decals on the inside of my shore power to remind/inform the technician who is hooking up to it. Next I installed gasket material around both panel openings in my overhead console. The gaskets are to prevent air leaks because the overhead console has a positive pressure in flight. Then I loosely installed the two overhead aluminum plates that cover the two openings. I still need to add my seatbelt bracket to the aft plate.
Panel installed
Panel installed
Ground power marking
Seats installed
Seats installed
