Brief Description: Door cylinder bracket / insulation
Finished cutting in the insulation around the L/R air inlet and forward C channel. Next I installed the L/R door cylinder brackets. Then the lower cowling was removed and the bump which came close to fowling the mixture arm was sanded smooth and re- epoxied. I also trimmed the vertical muffler hanger on the left exhaust. Ended the day by recharging the desiccant plugs
